Error 1320 on Open FPGA VI Reference Function
Updated Dec 16, 2019
  • CompactRIO Controller
  • myRIO-1900
  • LabVIEW FPGA Module
  • LabVIEW Real-Time Module
My real-time VI shows a broken run arrow.
I get the following error message on the Open FPGA VI Reference Function:
1320 : Propertynode (arg 2) in FPGA_IntfRefDatatypeFromTypeDef.vi:3390002->FPGA_IntfInputRefInfo.vi->nirviCallRefInfoPlugins.vi:7220002->nirviSpecifyOpen.vi:7230001->nirviDoOpenUpdateState.vi:500002->nirviOpenFPGA.xnode:nirviOpenFPGA_UpdateStateWithRef.vi->nirviOpenFPGA.xnode:nirviOpenFPGA_UpdateStateWithRef.vi.ProxyCaller
This error massage can occur, when you already used the Open FPGA VI Reference Function,
and afterwards changed something on your project or the used VIs.
Often, the problem can be solved by deleting the Open FPGA VI Reference Function completely,
and then configure it again.
The same troubleshooting can help, when erros occur on other VIs from the FPGA Reference palette on your real-time block diagram.
