How to Programmatically Check If NI-SMU Channel Output Is Enabled/Disabled
Updated Dec 16, 2019
  • PXI-4110
  • NI-DCPower
I want to retrieve the Output Enabled property for a channel in PXI-4110 programmatically in NI LabVIEW. How can I do this?
Output Enabled property for a specific channel can be accessed using the Property Nodes in NI LabVIEW.
After opening a reference to the required channel via niDCPower Initiate.vi, pass it on to a property node, and you will be able to access the Output Enabled property as shown below:
