Unique Thread Identifier in TestStand
Updated Jan 6, 2020
  • TestStand
I am using a multithreaded TestStand sequence and need a way to identify the multiple threads.  What identifier should I use?
Built into TestStand there is variable Runstate.ThisContext.Thread.UniqueID which will give a unique thread identifier for each thread running within TestStand.  This method is preferred specially on machines where you have multiple instances of the TestStand Engine.
You can also use RunState.TestSockets.MyIndex assuming that there is a single execution and not multiple TestStand instances.
