Modify NI Configuration Export File (.nce)
Updated Dec 11, 2019
I would like to modify a NI Configuration Export File (.nce) created from another computer. Is this possible?
No, you cannot directly modify .nce files. If you need to modify NI MAX system configuration, export them as .ini or .txt files instead.
If you need to convert .nce file to .ini file, please contact National Instruments for support.
For more detailed information on how to export and import NI MAX system configuration, refer to this link.
