Can FlexLogger and LabVIEW Simultaneously Access Different Cards on the Same cDAQ?
Updated Dec 5, 2019
  • FlexLogger
I wanted to know the limits when FlexLogger and LabVIEW are been using at the same time with the hardware.
FlexLogger can use one card while LabVIEW uses another.  However, you cannot have both programs access the same card, even if it is different channels.
