Source Measure Unit Returns False Current Reading
Updated Jul 3, 2020
  • PXIe-4163
The current values returned by my SMU are 10 times higher than the signal value and 2 times higher that the set compliance limit.
I've changed the DUT, changed the scope and changed the code but the issue still persists.
What changes can I make to the code so that my device returns the correct readings?
This behavior can happen if you programatically set a range and a limit to the readings when also enabling autorange.
Once you use only one option your device should return the proper readings.
