Can I Use Letters for the Axis Ticks in LabVIEW Graphs?
Updated Dec 16, 2019
Can I use letters/strings for the ticks instead of numbers in LabVIEW graphs or charts?
There is no function where you can change the numbers directly to letters.
You can use a simple workaround:
  1. Use your data points to create an array of equivalent letters. (0=A, 1=B....), see additional information in related links.
  2. Hide the ticks of you axis.
  3. Lay the Picture/text file with the letters/strings over the hiden ticks labels of the axis.
