Programmatically Disable a Target in System Definition
Updated Nov 28, 2019
  • VeriStand
I have several Real-Time Targets in a one System Definition File. Is it possible to programmatically Disable one of the targets in LabVIEW? Are there any APIs or Property Node to disable the targets in LabVIEW?
I can do it in VeriStand as shown below. I need to do the same steps in LabVIEW.
You can use DisableTarget property Node as shown below.
You can set this property node to True to disable the target.
If you want see more details about System Definition API, please refer the related links below.
DisableTarget Property
You can Gets or Sets the Boolean flag indicating whether a target is disabled.
Namespace : NationalInstruments.VeriStand.SystemDefinitionAPI
