このコンテンツは設定された言語で表示できません。
Using the PFI Trigger Line on a PXIe Chassis
Updated Mar 11, 2022
  • PXI Chassis
  • NI-DCPower
  • NI-DMM
  • FlexRIO
  • NI-FGEN
  • NI-SCOPE
I have a PXIe card which I need to start using an external hardware trigger. I am using a PXI Express Chassis with the Timing and Synchronization Option like a PXIe-1095 or PXIe-1092, which have 4 PFI lines. Is there any way I can use these as my trigger inputs?
Some drivers like NI-DAQmx, NI-DCPower or FlexRIO allow pointing directly to the PFI lines in the chassis to trigger the card, as shown in the code snippet below.
In NI-DCPower and other drivers it will look very similar, as shown in this picture:
If you are working with a card that uses a driver that returns an error when attempting this, or does not have an option to point directly to the PFI lines in the chassis (like NI-DMM or NI-Scope, as of November 2019), you can use the method shown in the code snippet below to connect the PFI lines in the chassis to the PXI Trigger Lines in the chassis backplane and point the card's trigger to the chosen PXI Trigger Line instead..
Note: To use the code snippets, right-click and download them, then drag them into a blank LabVIEW VI block diagram. The shown code will be automatically created.
  • The DAQmx Signal Routing VI's can be used to route the signal of the trigger from the chassis PFIs to the backplane trigger line. From this location the cards within the PXI(e) Chassis can use the signal which comes through the trigger line. You can reference the PFI connector with the terminal name /[hostname]/PFIn where [hostname] is the chassis' name on NI MAX and n the number of the PFI you want to use.
  • The same syntax can be used in drivers that need the trigger source to be specified as a string, like FlexRIO.
