Error 56003: Could Not Process LabVIEW VIs in TestStand Deployment Utility
Updated Dec 2, 2019
  • TestStand
I am trying to create a New Deployment using TestStand Deployment Utility. However, I am unable to and get the following error message:
Internal Error Code 56003 Processing VIs..
Could not process LabVIEW VIs. Fix any broken VIs before you rebuild.
Here is an example of the error I am seeing:
To resolve this error, ensure that there are not VIs in the user.lib directory with the same file name. If there is, remove the duplicated file.
If this does not resolve the issue, please contact us for further assistance.
