The correct version of all the software required needs to be installed on your PC for it to be downloaded onto your real-time target. For each version of LabVIEW, the matching version of the software listed below needs to be installed.
- Required LabVIEW version
- NI CompactRIO and Drivers
- LabVIEW Real-Time Module
- LabVIEW FPGA Module
Once all of the software have been downloaded the correct version will show up under "Add/Remove software".
Compatibility
To ensure the version of LabVIEW is compatible with the RIO device please use the tool on the following paper:
Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, and EtherCAT. The LabVIEW version which you download must then be the same as the version of LabVIEW Real-Time and LabVIEW FPGA Modules as described in the following article:
LabVIEW Compatibility With the Real-Time and LabVIEW FPGA Modules. The compatibility of LabVIEW with the NI-RIO driver can be seen in the following article:
NI-RIO and LabVIEW Version Compatibility
