Why I Am Unable to Access the Block Diagram While the VI Is Running?
Updated Jan 6, 2020
I open my VI and can not access the block diagram once the VI is running, why is this happening?
Change the Run-Time mode under Edit >> Run-Time Menu... and change the menu type from Minimal to Default.
