Can I Access My C Series Modules Last Calibration Date When Using FPGA Mode?
Updated Dec 27, 2019
  • CompactRIO Controller
  • C Series Digital Module
  • LabVIEW FPGA Module
I am using my C series modules with a compactRIO on FPGA mode. How can I get access to the last external calibration date of it?
I can see that this is possible with a DAQmx Calibration Info node, but I want to know if it's possible with FPGA mode.
It's not possible to access the DAQmx property node while of FPGA mode. The suggested workaround is to use one of the new cRIO 904x and 905x that support the DAQmx driver and get this information on the Real Time VI.
You can check this tutorial for more details about Using CompactRIO with the NI-DAQmx API.
