Screen Frozen After Changing Embedded UI Resolution on cRIO-9033
Updated Nov 19, 2019
  • cRIO-9033
  • CompactRIO Controller
  • NI Linux Real-Time
I am using cRIO-9033. After I have changed the embedded UI display resolution, set it to a resolution of 1920 x 1080, when I tried to run the VI, the screen went frozen.
Why is this happening?
In order to stop this from happening, most likely you have to do is try to format your CompactRIO controller. Note that by performing this, you may lose all programs and configuration data on your controller when you format the disk. Make sure you have a back up copy of any files you may need from your controller, and make a note of your IP configuration.
What if the problem still occurs? You can try to change the embedded UI resolution to your desired resolution from the Linux command line and try to run any VI again to see the result.
