Specifications for Virtualbench Measurements Rise Time and Fall Time
Updated Dec 6, 2019
  • VirtualBench All-in-One Instrument
I am performing the measurements Rise Time and Fall Time using the VirtualBench Application. What specifications apply to these measurements?
The current VirtualBench application the following measurement specifications are used:
As seen in the Measurement Setting window, rise and fall time icons appear as follows. The horizontal lines are indicative of the 10 and 90% bounds.
You can see the measurements below the Oscilloscope Graph using the NI VirtualBench application.
Figure: Virtualbench interface showing rise and fall time
