How to Calibrate NI Vector Signal Transceiver
Updated Dec 16, 2019
  • PXIe-5644
  • PXIe-5645
  • PXIe-5646
I want to calibrate NI Vector Signal Transceiver module but when I open the NI MAX I do not find any Self Calibrate button. I only have Self Test button, how I am going to do the Self Calibrate for the module ?
If you need to Self Calibrate the module, the utility can be found in Windows by navigating to Start>>All Programs>>National Instruments>>Vector Signal Transceivers>>VST Self Calibrate. You can select which NI VST module that need to be Self Calibrate and press Start to begin the test. If the calibration passes it will show Calibration successfully completed and if the calibration fails it will prompt an error.
