XNode Is Not Executable After Duplicating FPGA VI Project
Updated Aug 2, 2021
  • LabVIEW FPGA Module
I have tried duplicating the example FPGA projects and changing the target cRIO device and got the following errors:
Read I/O Method: XNode is not executable
Get I/O Read Status Method: XNode is not executable
With the details saying:
This node is not executable because an unexpected error occurred during code generation.
To solve this error, the following nodes need to be removed from the block diagram and replaced with the new ones from the Functions palette:
