Both CLIP and IP integration nodes require that the Xilinx compilation tools are installed locally as these features rely on functionality from these tools to work properly.
If you already have installed Xilinx compilation tools on your machine, check the
compatibility of your system , assuring the hardware, software, and OS are all compatible.
Note: If you are using Windows 10, also utilize
this flow diagram to check the compatibility of your system.
