Getting No Output When Using Unflatten Pixmap VI
Updated Nov 11, 2019
I am processing image information using pixel arrays, however, I get no output after using Unflatten Pixmap VI.
What is happening and how do I fix it?
Check the output data for all pixmap outputs, and use the valid pixmap value.
When using a Unflatten Pixmap VI to convert the data to a 2D array, only one of the pixmap outputs (24-bit, 8-bit, 4-bit, or 1-bit) is valid at a time.
This depends on a type of graphics file, and thus it is essential to check and use appropriate output.
