DIAdem Does Not Show All Channels
Updated Mar 6, 2020
  • DIAdem
I have a huge number of channels that I would like to plot in my DIAdem report. However, the report graph is only showing the first 250 channels.
DIAdem report has a limitation of plotting maximum 250 channels in a single graph.
If the different channels' data is shifted along the horizontal axis, they can be concatenated into a single channel to decrease the number of channels to be plotted and by that fit in the limit of maximum 250 channels. For this, the Concatenate channels example can be used as a reference, which uses a script to concatenate several channels with identical names from different channel groups.
