How Can I Invert the X-Axis of 3D Contour Plot?
Updated Nov 7, 2019
I want to invert the x-axis range so that the zero point does not start from center of the plot.
I can use projection palette to change the orientation (view angle) of plot, however, I cannot find a way to invert the axis.
Please follow the following steps to invert the x-axis.
1. Right-click the 3D Contour Plot indicator on the front panel
2. Select 3D Plot Properties
3. Select Axis from Category
4. Select X Axis
5. Select "Inverted" under Range
6. Select OK
