Resolution Problem of PXIe-8880
Updated Apr 27, 2023
  • PXIe-8880
Although the GPU driver, AMD Radeon E6460, is installed, PXIe-8880 cannot recognize GPU driver. How can I solve this problem?
For the latest PXIe-8880, there are cases where GPU driver is AMD Radeon E6465. So you need to install E6465 driver, not E6460. Please download E6465 drivers from the following link: E6465 Drivers Download
After installing the correct driver, the resolution of PXIe-8880 will be fully supported and recognize GPU driver correctly.
