NR Generation: Number of Resource Blocks is invalid
Updated Oct 2, 2024
  • RFmx Waveform Creator
On RFmx Waveform Creator, after changing the Channel Bandwidth of a NR Carrier Definition, I get error message:
NR Generation: Number if Resource Blocks is invalid.
Under Carrier Definition, go to BWP and change the Number of RBs to make sure its not larger than the maximum specified. This will clear the error message.
You can also set the Number of RBs to -1, this will default it to its current maximum.
