When you encounter unexpected behavior, it is usually due to an incompatibility between LabVIEW and Windows OS. Sometimes using an incompatible LabVIEW version with Windows OS may work, but we do not ensure that they can work together without any issues all the time.
Therefore, it is imperative to confirm that your LabVIEW version and Windows OS are interoperable with one another. You may check your compatibility between LabVIEW and Windows OS from here:
LabVIEW and Microsoft Windows Compatibility.
