Samples of SystemLink data preparation and analysis automation can be found in the folder below.
C:\Users\Public\Documents\National Instruments\Data Preprocessor
C:\Users\Public\Documents\National Instruments\Analysis Server\Configuration For example, when testing *.anp files used in analysis automation, you can run and test them in DIAdem as follows.
When using the analysis automation function on SystemLink, it is necessary to create a DataFinder instance. You can check how to create a DataFinder instance in
this document .
