The Sound Files VIs are limited to writing or reading files under 2 GB of size because they call a DLL that uses int32 as input. Two GB is a common limitation for any API that uses int32 values because the maximum number representable by a signed 32-bit value is 2,147,483,647. WAV files themselves have a hard limit of 4 GB because the header contains an unsigned 32-bit file-size field.
To avoid this issue, limit the size of the .wav files being read or written to less than 2 GB.
