Maximum Number of Fiber Optic Cables Supported on PCIe/PXIe-839x
Updated Dec 4, 2024
  • PXIe-8398
  • PCIe-8398
  • PXIe-8394
  • PXIe-8399
I saw that the new fiber optic cables for the PCIe/PXIe-8398 only have an x4 link. So, if I want to increase the bandwidth of the connection, how many cables can I connect to the module?
The number of fiber optic cables connected to your device must not exceed the limits noted in the table below:
Device (Hardware Revision)Maximum Number of Fiber Optic Cables
PCIe-839x or PXIe-8394/8398 (rev H or newer)2 total
PXIe-8394/8398 (rev G or older)1 total
PXIe-8399 (rev H or newer)2 per bank, 4 total
PXIe-8399 (rev G or older)1 per bank, 2 total
However, the hardware doesn’t allow you to stack cables as you can with copper cables to create an x8 or x16 connection. The modules will always establish a x4 link per system.
You can determine the revision of the MXI modules following the instructions in this document.
