I want to using PXIe-5841 generate AM modulation with 250Hz. When I configurate the AM frequency to 250Hz in RFSG Soft Front Panel, it will automatic change the value to 763Hz and pop out
Warning: AM Modulation frequency has been coerced within the minimum modulation frequency on the device.
However, I can't find PXIe-5841 supported AM modulation frequency range mention in specification. How should I know whether it can support generate AM modulation frequency that I wish to?
