Programmatically Access Metadata From a .TIFF File with LabVIEW
Updated Apr 5, 2023
Programming Language
  • C# .NET
I need to be able to read the metadata in my TIFF images. I can't seem to find any VIs which will read the TIFF header text. Is there any workaround to accomplish this?
It is possible to access this information by making use of .NET library functions, the process to achieve this is the following:
  1. Create a reference to the FileStream .NET class.
  2. Use a static .NET Property to reference the BitmapFrame class.
  3. Reference the Metadata property of the BitmapFrame class, this results in a ImageMetadata reference.
  4. Use the To More Specific Class function to reference the BitmapMetadata class from the reference obtained before for ImageMetadata.
  5. Reference the desired properties with the BitmapMetadata property node.
