This issue may occur if there are any security policies configured within the network the computer is connected to that can block the HTTP messages being transmitted from the PC to the local VBAI Engine or if the
VBAI API Interface.ini is corrupted. To identify what is causing the issue and solve it, please review the steps listed below:
Online PC
To validate if the issue is related to your network, disconnect your PC from the internet and try to run your VI again. If the execution is completed successfully, configure your network following the guidelines listed in
Configuring Software and Hardware Firewalls to Support NI Products. Double-check that TCP ports 80 and 3580 are not being blocked by a firewall or third-party software. If you need further assistance or do not have enough rights to make any modifications to the system, ask your IT Team for support.
Offline PC
If error -354705 appears while the computer is offline, that could mean that the
VBAI API Interface.ini is corrupted. To solve the issue, try the steps below:
- Navigate to C:\Program Files (x86)\National Instruments\Vision Builder AI 20XX or C:\Program Files\National Instruments\Vision Builder AI 20XX, depending on whether you are using the 32-bit or the 64-bit version of VBAI.
- Identify the VBAI API Interface.ini file as shown in the image below.
- Delete it and re-run your VI to regenerate the INI file. Verify if the issue is solved.
- If the issue is not solved after executing steps 1 to 3, open the VBAI API Interface.ini file and verify if the allowmultipleinstances=True flag is there. If it is not there, add it manually to the INI file, as shown in the image below, save the file, and try to run your VI.
