In the Custom Device of NI-VCOM, I intend to only send CAN frame ADAS_General_Status_1 to the CAN network, so I just import this message under the configuration tree of VCOM.
After deploying the VeriStand project, I enable the transmission of this message. I can see CAN frame ADAS_General_Status_1 as well as CAN frame ADAS_General_Status_3 which is unexpected in the Bus Monitor.
What should I do to only send the CAN frame ADAS_General_Status_1?
