Unexpected CAN Messages Sent with NI-VCOM in VeriStand
Updated Dec 2, 2024
  • CAN Interface Device
  • VeriStand
  • Vehicle Communication Toolkit
In the Custom Device of NI-VCOM, I intend to only send CAN frame ADAS_General_Status_1 to the CAN network, so I just import this message under the configuration tree of VCOM.
After deploying the VeriStand project, I enable the transmission of this message. I can see CAN frame ADAS_General_Status_1 as well as CAN frame ADAS_General_Status_3 which is unexpected in the Bus Monitor.
What should I do to only send the CAN frame ADAS_General_Status_1?
Only importing one frame in the configuration tree of VCOM doesn't mean that only this frame will be transmitted. When creating VCOM Descriptor, if you don't want to send other frames by default, the IsRbsEnable of these frames should be configured to False.
If you just want to enable one frame and disable other frames in VCOM Descriptor, you are recommended to select Change RBS Default Values in the Datapool, then change the default values to false for all messages before you import the dbc file. By doing this, you will set the IsRbsEnable of all frames to False. Then you just need to change the IsRbsEnable of the needed frame to True
Note: The VeriStand Custom Device is called NI:VCOM from VCOM 2023Q3 rather than Provetech:RBS.
