Write Palete VI View Format Input Changes Not Applied in LabVIEW
Updated Aug 30, 2023
I am experiencing an issue with the Write Palette VI in LabVIEW where changes made to the View Format input are not reflected in the results. I have attempted to select different options such as Icons, Text, and Icons and Text, but the palette always appears the same.
To ensure that changes made to this palette configuration parameter are properly applied, please follow these steps:
  1. Go to Tools >> Options
  2. In Controls/Functions Palettes, select Category (Standard) in the Palette option. Category Standard.png
  3. Click OK to save the changes.
  4. After making the selection, the created palette will display differently based on the setting passed to this VI, ensuring that the changes are properly reflected in the results
