Read Disk Drive Properties in Windows Using LabVIEW
Updated Aug 30, 2023
Other
  • Microsoft Windows
I would like to be able to read disk drive labels, disk space, or disk type from LabVIEW.
A simple way to do this is to leverage the Windows kernel32 DLL. Use the Call Library Function Node in LabVIEW to call this DLL, and then use functions like GetVolumeInformationA or GetDriveTypeA to read the properties you need.
For example, to get the disk drive name:
You can also use Command Prompt and the System Exec VI  with Windows Management Instrumentation Command-line (WMIC) commands.
For a list of drives in a machine you can use the List Folder Function with an empty path wired as the input.
