The Item Named DRAM Manager.lvlib Cannot Be Loaded in the Project When Using FlexRIO Camera Interfaces
Updated Aug 19, 2024
  • PXIe-1486
  • PXIe-1487
  • PXIe-1488
  • PXIe-1489
  • FlexRIO
After upgrading my FlexRIO driver I get the following error when loading my Getting Started FlexRIO Integrated IO LabVIEW example project for the PXIe-148x cards:
The Item named DRAM Manager.lvlib cannot be loaded in the project. The Item will be deleted from the project.
The DRAM Manager.lvlib is a standard part of the Getting Started with Integrated IO example for the FlexRIO Camera Interface cards. It is installed with the driver and the error suggest there is an issue with compatibility or opening the installed version.
Follow these steps to resolve the issue
  1. Ensure compatible software versions are being used. The following resources may help:
  2. Uninstall the FlexRIO driver that was upgraded or if you haven't upgraded yet, uninstall the old version before you install the intended new version.
  3. Install the new FlexRIO driver as a fresh install. For example, the FlexRIO 2023 Q1 release.
This should resolve the missing files, link issues or incorrect versioning of the library.
