Error -2147024156 When Running My LabVIEW OPC Code
Updated Feb 21, 2023
  • LabVIEW 2022 Q3 Full
I received the following error when trying to run my LabVIEW code:
Error -2147024156 occured at getopcserverlist.vi
Possible reason(s):
The requested operation requires elevation
This issue could be because LabVIEW need to the run as administrator.
Righ-cllick on the LabVIEW.exe file located on C:\Program Files (x86)\National Instruments\LabVIEW 2021
and click on 'Run as administrator'
For a long-term solution, you can right-click on the LabVIEW.exe, go to Properties, then Compatibility, and mark the checkbox 'Run this program as an administrator'
