Microsoft .NET 2.0 SP1 or Higher Required by the USB-TC01 Launcher
Updated Feb 15, 2023
  • USB-TC01
A pop-up requiring Microsoft .NET 2.0 SP1 or higher is appearing when running Temperature Logger from USB-TC01 Launcher.
How can I use the USB-TC01 launcher if this pop up is appearing?
This behavior is a known issue identified by Microsoft for certain Windows applications.
In order to get past this pop up you will need to install the .NET Framework 3.5 and then enable its features via Windows settings.
You can install the .NET Framework from the following link:
External: Install the .NET Framework 3.5 on Windows 11, Windows 10, Windows 8.1, and Windows 8
After installing the appropriate software you will need to enable the .NET Framework Support via Windows Settings.
After the installation of the .NET framework, in Windows Settings select Apps and Features and then select Programs and Features:
Then select Turn Windows features on or off
Finally, you will need to fill the ".NET Framework 3.5 (Includes .NET 2.0 and 3.0)" checkbox.
If the .NET 3.5 installer doesn't perform the installation, you can contact your IT deparment or Microsoft for more options.
