Incorrect Filter Property on NI-9253 Calibration Procedure
Updated Feb 13, 2023
  • NI-9253
The NI-9253 Calibration Procedure indicates in step 6.c of the Accuracy Verification section the property you need to set for the filter. However, the listed property (Analog Input >> General Properties >> Digital Filter >> Notch >> Center Frequency) does not appear to exist. There is no Digital Filter property listed under General Properties. What should be the correct property to set the filter for calibration?
The correct filter property is Analog Input >> General Properties >> Filter >> Frequency.
