I would like to implement an analog trigger in my project with PXIe-4309. When testing PXIe-4309 with Flexlogger, I am able to configure analog trigger in the Triggering section of the Logging Specification tab, as illustrated by the image below.
However, when I try to implement analog trigger in LabVIEW, I will get the following error:
Error -200077 occurred at DAQmx Start Trigger (Analog Edge).vi:7160001
Possible reason(s):
Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Property: Start.TrigType
Requested Value: Analog Edge
Possible Values: Digital Edge, None
