Unexpected Result from Expression Node on LabVIEW 2021 and After
Updated Dec 4, 2023
Programming Language
  • LabVIEW G
I am migrating my LabVIEW 2020 project to LabVIEW 2021. I realize the result of expression node changes on LabVIEW version 2021 and after. The difference can be found when the result of unsigned integer input is negative. Image below illustrated this behavior. How can this issue be resolved?
To resolve this issue in LabVIEW version 2021 and after, kindly use To Double Precision Float and To Unsigned Integer on the inputs/outputs of the node to get the previous behavior.
solution
NI apologize that this behavior change was not noted in the documentation, but it was a bug fix. We intend for the Expression Node to produce the same output as the equivalent syntax in G. Previously, the node internally treated values as floating point.
