The execution speed of your Python code will depend on a number of factors, including:
- How the API is called.
- The choice of API used for the task.
- Software limitations.
To determine whether your execution speed can be improved, work through the steps below:
1. Minimise the number of times the task is opened and closed.
- When a task is created and configured, Python must locate and load the DLL associated with initialisation. This will add time to the execution.
- If possible, initialise the task once at the beginning, and repeat read/write operations without closing or re-initialisation.
- Note: a DAQmx task should be opened once and closed once when you're finished working with the hardware.
2. If using analog inputs/outputs, experiment with
stream_readers and
stream_writers.
3. Ensure that you are timing the task correctly.
- Import a Python module to time specific sections of code. Note: a common module is the datetime module.
- Obtain the time before a function and again immediately after the function to calculate the execution time. Repeat this with each function to determine which function is taking the longest to execute.
- Below is an example of timing a DAQmx write.
import nidaqmx
import datetime
with nidaqmx.Task() as task:
#get module and channels
module1 = nidaqmx.system.System().devices[1].ao_physical_chans.all.name
task.ao_channels.add_ao_current_chan(module1)
#configure timing
task.timing.samp_timing_type = nidaqmx.constants.SampleTimingType.SAMPLE_CLOCK
acquis_type = nidaqmx.constants.AcquisitionType.FINITE
task.timing.cfg_samp_clk_timing(rate=24000,sample_mode=acquis_type,samps_per_chan=24)
#obtain start time, execute a write function, and then obtain the end time
st = datetime.datetime.now()
print(task.write([[0.001,0.002,0.003], [0.004,0.005,0.006], [0.007,0.008,0.009],[0.001,0.002,0.003], [0.004,0.005,0.006], [0.007,0.008,0.009],[0.001,0.002,0.003], [0.004,0.005,0.006]], auto_start=True))
et = datetime.datetime.now()
#calculate the difference between the start and end time, and print the result
ft = et - st
print(ft.microseconds)4. Consider whether the following software limitations are contributing to your execution speed.
- Windows operating systems are undeterministic. This is a result of the background tasks, updates and processes that are constantly running and cannot be prevented. As a result, it is expected that code will take at least a few milliseconds to complete (potentially more, depending on the complexity of the code).
- The Python API is a wrapper on top of C API. As a result, Python must call into DLLs to execute each function. Each DLL requires processor time, so consider modifying your code to call into as few DLLs as possible.
- The PC's CPU load will have an impact on code execution time. If the PC is running background applications, processes or updates, the code will take longer to execution.
