There are two types of right-click menus will be shown on the library files that were created under project library. One of the menus has the option to remove the library file.
Meanwhile, another menu does not have the option to remove the library file.
The reason that there are two types of right-click menus is because the first library file is not password protected, while another one is password-protected and locked. When the library file is locked, users are not able to add or remove items from the project library. Users need to key in the correct password to access the password-protected library files.
