Determine State of Switch Module's Isolation Relay
Updated Jan 12, 2023
  • PXIe-2541
  • PXI-2541
  • NI-SWITCH
I am using PXIe-2541. Based on the hardware diagram I obtained in Help file, there are isolation relays as shown in the image attached below.
Hardware Diagram
I would like to know how to get the status of the isolation relay in LabVIEW.
The status of the isolation relay can be obtained using niSwitch Get Relay Position.vi. Below is an example of it:
example
