Troubleshooting NI Linux Real-Time Controller Crashes
Updated Feb 17, 2026
  • CompactRIO Chassis
  • LabVIEW Real-Time Module
  • Phar Lap
  • I have a CompactRIO (cRIO) controller that keeps crashing when I run Real-Time LabVIEW code. How can I troubleshoot this?
  • What factors can cause a Real-Time controller to crash?
Crashes on Real-Time controllers can be caused by a range of software or hardware factors. Follow the steps below to narrow-down the possible causes of your crash.
  • Locate the Real-Time Error Log file and search for error details.
    • Refer to Error Log File for My Real-Time Controller Crashes for instructions.
    • The error log will list LabVIEW, Real-Time and exception errors. Once an error is identified, enter the error code into the NI website to search for further troubleshooting guidance.
  • Verify that the controller's CPU usage does not exceed 75%, and that there is plenty of available memory.
  • If the controller is running LabVIEW code, simplify the code to isolate the section that causes failure.
    • If the crash occurs inside a Real-Time executable, verify whether the same behaviour occurs from the LabVIEW development environment.
    • Use Diagram Disable Structures to disable sections of code.
    • If loops are used, ensure that there is adequate timing in place. If timing has already been implemented, check whether the problem persists when loops execute less frequently.
    • Minimise the amount of Front Panel objects.
    • Refer to Troubleshooting LabVIEW Crashes for further guidance on troubleshooting LabVIEW code.
  • Ensure that there are no other scripts or processes running on the controller that could cause it to hang.
  • Check the status of the controller's LEDs after the crash.
    • Refer to your controller's user manual to determine if the LEDs are indicating a specific problem.
  • Reformat the controller and reduce the installed software set.
  • Verify whether a simple VI works on the controller.
    • For example, create a Real-Time VI consisting of a While Loop  with a Wait (ms) function set to wait for 1000 ms.
    • If a simple VI reliably causes crashes, it's possible that hardware timing has failed on the controller. Contact NI Support for further assistance.
  • If your controller is externally powered, verify that the power supply meets the specifications of the controller.
    • Insufficient power ratings could cause the system to draw more power than it has available and might crash your system.
If the time to reproduce the crash is long and the crash is safe to reproduce, you can increase the frequency of a loop to potentially trigger the cause of the crash faster. If a sped-up loop causes the crash to occur faster than usual, then:
  • You have isolated the issue to a VI/function inside that loop, and/or;
  • You can test different troubleshooting steps faster and skip the long time between crashes.
