How to Create Group in SystemLink System Management
Updated Jan 5, 2023
  • SystemLink
SystemLink System Management can be used to configure systems, view system settings, set up alarms and notifications to monitor system health. It is common that we have a lot of systems and need to group them under a certain group name.
This article will show you how to create a group for your systems in SystemLink System Management.
For a fresh installation, the default behavior puts systems under a section labeled "Empty". You can create your own group by following the steps below:
  1. Select the Edit Grid button (it's the 3 vertical bars in the upper right of the grid area, in the same row as the grid column headers), then select Grouping and choose Group.
  1. Select the system that you want to group, then select Settings and change the properties to Group. After that, give the name of your Group.
After finished, all your selected Systems will be under the same group, here is the example for your reference:
