1. Open Bus Log Converter in DIAdem NAVIGATOR2. Load the BLF File using the option Vector BLF as the File type. 3. After that, configure the BUS database.4. Here add the database under the following settings. The bus number and the bus name should match the network name in the database. 5. The BLF data should be correctly loaded under these settings.
