Can I Use Cutom Baud Rates With My CAN Modules in FlexLogger
Updated Jan 15, 2024
  • FlexLogger
  • FlexLogger Plug-In Development Kit
I'm getting readings in NI-XNET Bus Monitor from my CAN module using custom baud rates, I can also get the readings working in LabVIEW, but I can't find these settings in FlexLogger. Are custom baud rates supported in FlexLogger?
FlexLogger does not support custom baud rates.
If you need to get readings with custom baud rates you can useĀ FlexLogger Plug-in Development Kit, this will allow you to leverage LabVIEW and implement a custom plug-in to get the readings you need in FlexLogger.
