TTL/CMOS Compatibility With Counter and Digital Modules
Updated Dec 13, 2023
  • Counter/Timer Device
  • Digital I/O Device
  • I have a Counter/Timer module or a Digital I/O and I want to know if it is compatible with TTL/CMOS logic levels.
  • I want to use my NI module with a CMOS input/output, but the Logic Level Table in the datasheet indicates voltage values that are not withing the ranges for TTL and CMOS. Is the device still compatible?
To find out if a device is compatible with TTL/CMOS logic levels, you should refer to the specifications of your device and find the compatibility in the I/O Characteristics section:
This means that NI has tested these cards with typical TTL/CMOS inputs or outputs and confirmed that the logic levels are read/written correctly from the cards, considering the voltage, impedance, and current handled by TTL/CMOS inputs/outputs.
Notice there is also a Digital Logic Levels table in the specifications of the device:
This table can be used when the device that will interface the NI module is not a TTL/CMOS device, so the information on this table should be taken into account for that custom design.
If the device that will interface the NI module is TTL/CMOS, this table can be ignored.
