Error -307735 When Using PMC-5565PIORC in VeriStand
Updated Dec 7, 2022
  • cPCI-5565PIORC
  • VeriStand
I have 2 PXIe-8861 running NI Linux Real-Time OS. When I use GE cPCI-5565PIORC to establish communication with each other in VeriStand 2019 R3. The following error is shown:
VeriStand 2019 R3 doesn't support reflective memory cards such as the GE cPCI-5565PIORC on Linux RT. But, it supports them on Pharlap RT. The early releases of VeriStand 2020 can support reflective memory on Linux RT, but the support has a very significant performance issue due to a driver regression before VeriStand 2020 R5. VeriStand 2020 R6 or a newer version is strongly encouraged to be used on Linux RT.
