Can I Execute Script Created by DIAdem Professional and Crash Analysis Toolkit by Use of DIAdem Base License?
Updated May 20, 2025
  • DIAdem
  • DIAdem Crash Analysis Toolkit
I have created a script by use of DIAdem Professional and Crash Analysis Toolkit. When I deploy it to the PCs, can we execute it by use of DIAdem Base license? Or, do we need DIAdem Professional license + Crash Analysis Toolkit license for the PCs just to execute the script?
You can execute your script only with DIAdem Base license.
For example, if you have two developers in your group and 100 of PCs to execute script created by the developers, the two developers need to have licenses of DIAdem Professional and  Crash Analysis Toolkit to create script. For the execution of the script on 100 PCs, they need to have DIAdem Base license for the PCs. When there is no possiblity that you will use more than 30 PCs simultaneously, then by use of network license you can reduce the number of DIAdem Base license to 30 seats while all PCs need to connected to license server.
